Isn't posible to use the plugs for safety isolation whicth chassis ?
It is possible, a GM internal regulator alternator plug works on one side of the HEI module, both are 1/4" spades, on the other side one is 1/4" and one 3/16" spade. The only connector I could find was the pigtail of a GM pickup coil.
