My dad's car had a hot start problem caused by a too-wide reluctor gap in the Mopar electronic distributor. We closed it to around .008 and that fixed it. I'm not sure if that fits with your other symptoms, but as long as you're checking things it couldn't hurt to check that too if you have something like a business card around that thickness you can slip in and check.
