Originally Posted by Nukechargerboy
Check the neutral safety switch, might be a bad connection or bad wire.
Check the one on the clutch pedal. On the 1970 B-body's its a green wire.
Did you replace the battery cables? Some reproduction cables are not properly sized (gauge wise) and when they heat up because they cannot handle the amperage and they can lose connection usually in the terminal ends. Try running jumpers to see if that corrects the issue.
