Bullet Racing Cams; Part No. 503000 Dur. @ .50 In. Ex. 257. 264. Lobe lift 4340. 4340. Separation 110. timing events .050 Int 22.5 OP, 54.5 Closed Ex 66 18 Duration @ .20 In 290 Ex 295 Gross lift 651/651 Lash hot .020 degree intake lobe to 106 10.7 CR, Pump gas (93)
Running a 275-60-15 rear for the street Have a Hoosier 10-1/2 we use on our 70 Charger to try on the RR just for some idea at the strip
