Ok so I found TDC using the dial indicator by marking it on the degree wheel and going back one revolution and marking at 0 again then dividing by 2 and setting the degree wheel at that number.
Then I mocked up my damper and timing tab and found this. Shouldn't it be lined up at zero?
