Originally Posted by John_Kunkel
The threads in the gear box are the same (1/2"-20) but the flare side of the fitting changed in '69 from 5/16" to 1/4" so you got a hose for '69-later. Just change the fitting in the box to '69-later. (1/4" flare P/N 2537386)
Thanks folks, I'll do some checking with some of my later stuff and find some earlier stuff to check, I know the fitting I pulled was out of a 71 box and most everything I double checked with PS is 69 and Up.
Careful, your character's showing!
