OK, finally got back to it. I moved the fuel filter from under the hood to the back of the car away from any heat. It is now between the fuel pump and the pressure regulator. Did the fuel flow test again with the 5 gallon bucket and there was no change, still 45 gph. I will drive it a few days and see if problem repeats.
