Originally Posted by moparx
over the years, i have assembled all the tools necessary for doing the alignments on my junk.
there are many reasons for this, but primarily, there are no shops locally i can trust to get me the specs i want, and i'm not going to be taking vehicles back 3-4 times to "get it close".
as was said previously, toe is the only setting on new stuff unless you obtain [or fab up] caster/camber plates.
the older stuff really responds to lots of caster, a good camber curve, and elimination of bump steer, but you have to work to get these advantages.
this may take way more than most will want, or can, do. therefore, i only do alignments for myself.
i know what's involved, what i want, and what i can accomplish. also, the older i get, the harder it is to do. hopefully, when i can no longer do this, i can find some young buck that will want to know how, and i can teach him.
beer
Yes THIS ^^^^^ I do the same thing.
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
