Welcome to Moparts, before you pick a cam, it would be best to decide on headers or manifolds, the cams would be way different between the two.
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
