Offset lifters load the link bars any time the pushrod is not truly perpendicular to the lifter bore. A 59° block has the worst angular alignment of any engine I have ever seen. Offset lifters in a 59° block would be the worst application I can imagine for loading the link bars/ rivets.
"use it 'till it breaks, replace as needed"
