I have been told that aluminum grows eight times more than steel when heated
That being said the first aluminum block (KB Street Hemi block with dry sleeves) I assembled had the sleeves installed so the top of them was right at .005 above the block deck, that motor leaked water around the sleeve tops from a water coolant passage under the head gasket until I took the block back to KB and they lowered the sleeves to .003 above and I used a different set of head gaskets designed for THAT block
Some of the information out here on race stuff is accurate on the same type of aluminum alloys, not all aluminum alloys grow the same at the same temps
