I don't know if anyone answered, the circuit breaker is in the driver side kick panel.
while wiring might be causing some issues, you could probably wait for them to shut off and then try tracing back the wiring till you find voltage again. that might help you narrow down the "bad" part to start with. Do the high beams work when this happens?
