Originally Posted by AndyF
Originally Posted by moparx
what regulator would you recommend andy ?
beer
Holley 12-880 should work but there are other choices depending on what size of line you are using and if you want o-ring or pipe fittings.
https://www.holley.com/products/fue...s/regulators/efi_regulators/parts/12-880
Thats cool, I see it has 2 different springs,
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
