OK, lets try this picture thing again. Pictures of my new project, a 49 Dodge 1/2 ton. All the sheet metal is there except the tailgate. I came with a title and a 4x4 Dakota chassis. I will need to make another trip to get the chassis. Plans are to put the sheet metal on the Dakota 4x4 frame, install a 5.2 Magnum and an od auto trans. Its going to be fuel injected. This will likely be a pretty slow build, unless the other truck sells and I have money to work with. Gene
