That same supplier sells a 4 piece repair panel kit with a smaller outer panels for a little less money. It turns out that I probably didn't need the larger panel & just 4 pieces instead of 6 but the difference was minimal & as a true believer in Murphy's Law I knew if I didn't get the larger ones I'd have needed them.
Smaller 4 Piece SetThere is a local Dodge dealer that got in a nice Ram on the used car lot that had the same rust. The truck was very clean except for the wheel lips.The next day there were black plastic fender flares on it.
There is no way they repaired the rust, painted it & put flares on in less that 24 hours. This same dealer has had a bad reputation for as long as I can remember.
