Well it looks like the Trick Flow intake is the one for me. I will be replacing my Solid Indy valley plate with a 2 piece unit like I should have done when I built this engine. The billet Trick Flow part looks like it should fit with Indy heads,they offer two styles looks like one for the 240 and one for the 270. I will take my Indy plate to Summit and compare it and see if it will work. I'm not looking for huge gains over the Performer RPM just something different to go with the new cam.
Thanks for the replies.
Gus
