Gentlemen,
I am in the process of trying to upgrade my 67 Coronet from Street/Strip to a weekend fun toy that can go around a corner or two without dragging the door handles.
So far swapped the big block for an aluminum headed 408 small block, bought 1.03 torsion bars, adjustable strut rods, 16 to 1 manual steering box.
The car already had an 11-inch power disc brake kit on it.
So now my focus is on Wheels and Tires, Rear Springs, Sway Bars, and Shocks.
I like the look of the 17 inch VN501, but I see that there are better tire choices in an 18 wheel aesthetically I like a little less wheel and little more sidewall.
Was thinking a 265 on 17x8 with 4.5bs all the way around if I can fit it.
1 and 3/8 Front sway bar and a 1 inch rear.
Shocks are rear springs I am little a little fuzzier on, I have never set a car up to do anything other than going fast in a straight line.
Only "road racing" was with Crown Vics and Chargers as part of my job.
Any advice or reference material would be greatly appreciated even if it is to tell me I am on the wrong track (no pun intended)
Not looking for a 9/10 track car, but a weekend fun machine.
Thank you in advance for any replies.
