The 10.5w31 works well for me. Been 1.240 on the foot brake. Very consistent 60fts usually plus/minus .005
Doug
Doug I would be curious to know what you rear suspension is and what power level in general. That’s an impressive 60 off the foot break.
Rear is 36" ladder bar, stock frame rails, Koni double adjustable, 120# rear spring. Front is Afco doubles revalved 50% stiffer, 6 cylinder torsion bars. 4.30 gear, Ultimate 9" converter (6000 flash), 3345 lbs. Motor has never been dynoed. I would imagine somewhere around 900HP. Car has been 9.00@150 best.
Doug
