I recently acquired a 7-1/4" rearend for my son's /6 Valiant that has a "cone" type sure-grip. I'm familiar with the "clutch" suregrips, and understand that the friction modifier is required for the clutches to work properly. is this also true for the "cone" type? I haven't had one of these apart before. Thanks!
May be i'm the only one, I use Red line 75W90NS GL-5 GEAR OIL
https://www.redlineoil.com/75w90-ns-gl-5-gear-oiland
https://www.redlineoil.com/limited-slip-friction-modifier
