That's what I have...9375. And it had 35s. It just plain gets too much fuel off the line. I have found that Holley makes only 2 pump cams for this carb. The stock Yellow and a White. The White does not use all the fuel in the pump while the yellow one does. I intend to order a couple of the White cams tomorrow. They are over $13 each. We'll see how that works.
Master, again and still
