you can drive with lights on ( including high beams ) and AC or heater at max speed and will release the load and voltage system. Just in case of maximun emergency because your home is 1 hour or so far and your batt could not hold the load. There is a solution or an option anyway being external, imposible to deal being internal.
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
