Originally Posted By burdar
Is this just an extra wire added, or is there cutting of old wires involved?
The MAD Electrical website has you cutting and splicing the factory wiring. You can read it here.
http://www.madelectrical.com/electricaltech/amp-gauges.shtml
I'm not doing it exactly that way on my 68 Dart. I'm just going to keep the factory wiring intact but add the extra bypass wire. The bypass wire has a very low likelihood of shorting to ground but I'm still going to add a fusible like to it for my own piece of mind.
I'll be using relays on the headlights and on the convertible top motor to take as much load off the bulkhead as possible. I already bypassed the AMP gauge and will run a volt gauge instead.
This is what I suggest and sell all the time. Make sure the bulkhead is clean/fixed, leave the factory stuff in place, bypass ammeter and run a protected wire from alt charge stud direct to the starter relay. Running relays further reduces the load on bulkhead.
Don't like the mad approach with linking wires together.
Plenty of ways to do this... Pick your parts pay your money.
