Originally Posted By 6PKRTSE
Originally Posted By ZIPPY
Scratch that, won't work due to lower rad hose interference.
Time for plan C.
Thanks for the advice, all.
It is tight down there. I welded on -20 weld on bungs & use -20 AN hose & fittings on my water pump housing to rad connections.
Yeah, that would definitely work!
Remote electric water pump would sure work....I'd probably love that...Not sure I could bring myself to do that without the usual belt drive to go with it, but, it would be cool.
It all adds up and I don't want to out-trick myself just yet. I'll hit the "easy" button on this and will go with plan C (pump cover with bulkhead fitting sticking out). That should give me nicer routing and (very slightly) less restriction, and can keep the other things a little closer to stock for the time being.
