sorry no pic but you basically want to set the upper ball joint as far back (towards the rear) as possible if you want more caster. so if you lay the control arm flat on a table the front bushing has the hole further away from ball joint and the rear bushing is closer to the ball joint. not sure if you will need all 4 or not. hope this was a little helpful.
i see wild bill beat me to it
