You need to define upgraded modern replacement headlights
Halogen headlamps would qualify on a 71 Demon.
LED headlights for a 71 Demon show about 1.1A per bulb.
Halogen headlamps for a 71 Demon draw ~5/2.75A (high/low beam), incandescent similar.
LED bulbs generally draw a few milliamps, but that is also dependent on how bright they are. If you had a specific bulb(s) in mind post a link.
IOW, not enough info to answer your question other then to say less that original.
They say there are no such thing as a stupid question.
They say there is always the exception that proves the rule.
Don't be the exception.
