Will clamping the front sections on my leafs help with my 60 ft ?? I just have the standard heavy duty leafs on there and a stock snubber.
Maybe, find out
AKA aside, they should help as long as there is room for improvement, I've seen .03 ET improvement on one of my old race cars by adding the clamps.
Made the car look better, even front travel on both sides, on the hit all the way through low gear also
Make sure all the normal race weight is on the springs when you tighten the clamps
