Man, that is some nice stuff. What would be the biggest bore for that block? Are you going to offer blocks with different bore spacing? Are all of your blocks water blocks or is there a solid block option? Rumor has it that the Indy solid block is stronger than their own water block. Does the same hold true for your blocks?
