Originally Posted By Satilite73
Maybe the push rod is different?
I installed a booster out of a mid '80's M-body in my wagon so I could run the aluminum MC without an adapter and the only issue I ran into was the hole diameter for the brake pedal shaft/pin was a different diameter. I just swapped out the push rod with the one originally from my wagon.
shruggy
I'm looking at a loaded booster with the master already attached so the proper pin should be with it.
No longer taking $h!t from anyone!
