How consistant is the car now? SS springs in a 10 second car, and most likely a torqueflite are going to want a VERY good shock. I think the best bet on the shock issue is to call a couple of DA shock manufacturers and get thier advice on what you need. Make sure you have that covered first, then see how big a tire you can put on it to get max consistancy with changing track conditions.
