Personally, at 213,000 miles, a motor miss, steaming and antifreeze out of the exhaust, and milkshake oil, I'd say it is time for a motor. Nothing short of a major repair is going to fix it now. Sorry. Gene
As much as you guys like to dispute everything, nearly everyone reached the same conclusion I stated very early.
A 94 Ram has the motor buried way back under the dash. Ever just changing head gaskets is a pita on them. Its faster and easier to pull the motor to change the heads/gaskets then it is to fight with them while still in the truck. Add milkshake oil and 213,000, and changing the motor for a lower miles motor in better shape just makes sense (if the truck is worthy of a motor), and may be cheaper then heads and gaskets. Gene
