I noticed i had a random popping out of my tailpipe on my 87 d150. It turns out that #2 plug is gas fouling. I did a compression test and it has 120 lbs.,not real high but it is a 1989 TBI engine. Can my carb be the culprit as the ignition system is good and the plug wires are good.
