Originally Posted By GTX MATT
Originally Posted By AndyF
Anyone younger than 30 doesn't even know what a carb looks like......
FALSE - I'm under 30, I have a carb, and tune EFI whistling
Madscientist, I'm not trying to convince you or say you're wrong. But you're a data freak and you don't want EFI? EFI will give you tons of data!
I think YOU would like tuning EFI. I think most people who have really tuned a carb and distributor would like it. I agree that alot of technology is junk, and over complicates stuff that's just not necessary. But EFI nowadays is pretty straight forward.
Once you calibrate it (and I would do it manually, not the self learn that Holley's systems have) if you target 12.2:1 you will hit it, if you target 12.8:1 you will hit it, within a few percent. And you can have a digital timing curve!
That said, I understand if you don't want EFI on your 50 year old car. I don't have it on mine, but have considered it. Honestly I will probably go EFI before I buy another carb for my car, but not ready to make the switch yet. The digital timing curve is actually a bigger deal to me than the Fuel Injection.
To answer your original question, if you get a TPS that outputs a 5V serial signal you should be able to log it with a laptop with a WB02 (I like AEM but many people also like Innovate). You just have to figure out how to convert those serial output signals, and read them on your laptop.
But what about RPM? whistling
Thanks for the replies guys.
I'm asking because when I start adding up the LM2 (just the single) I'm close to what I think I can buy a data logger for. And the I can measure RPM and drive shaft speed and use it to tune my clutch.
Since this is just my street car, I'm not wanting to make it too much like a race car, or I will hate it and sell it.
Seems like there is a tipping point where I go berserk and what should be a simple deal it becomes a whole 'nother deal where the car becomes too much like a race car. I sold the race car because I was tired of going to the track and all the other associated crap I didn't like dealing with.
I don't want my street car to become that. So I'm shy when I comes to adding stuff to the car. It's like being a heroin junky. Once you start down the slippery slope...
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
