It has been like that since I got the truck 3 years ago. The guy that I bought it from, had a small block kickdown set up that didn't come close working at all. I couldn't find a big block set at the time and went with a Lokar cable set up. I had someone sit in the truck and put the pedal to the floor, everything seems fine. Carb is at wot. What I will do tomorrow is have someone sit in it, floor the pedal and crawl under it to see if the lever on the trans is all the way back.
