Originally Posted By Michael Ecks
Proper adjustment is with the caruretor at wide open throttle the lever on the transmission should be all the way to the rear. Essentually both throttle lever and tranmission pressure lever should hit the end of thier travel at the same time.
Here is the tricky part, with the throttle fully closed, the transmission lever should still be back about half way, or maybe just a little less.
Wrong, and wrong. tsk
That link should be banned from the www and the guy who wrote it should be bent over a barrel and.............. eek
To the OP, what carb, stock or aftermarket? If aftermarket does it have the correct Mopar throttle lever adapter?
The INTERNET, the MISinformation superhighway
