Take a hard look at the top of the valve train parts as they are now, adjusters and pushrods, check the torque on the shafts and go from there scope
If you don't find anything up there remove the oil filter and cut it open and look real hard between the pleats for small debris, hopefully you won't find any cam and lifter debris luck scope
Please let us know what you find up
