I had a shifter like that and it was always loose and hard to shift as you have to push down on it to go from park to another gear. I went back to the stock shifter and suggest that for you also..check torsion bar supports and frame under the battery on both sides. I actually found two cars with frame issues on the passenger front.yes passenger side..hard to see on the ground but better on a lift
