Ran one on the last engine break-in. Crank gear was a sloppy fit on the crank and required shim stock shimming for a zero fit. Cam bolts were cheap and required replacement. Buttons on idler gears grooved timing cover; nice little circles like eye balls after a few hours of run time.
But, FWIW my memory tells me it was a China brand. So....
