The whole key to this is if the car hooks it will kill the 8 3/4. If you only run it with street tires it will spin or your launch will be so soft it won't be a problem. If you put slicks on it,save your money and get a Dana. I have killed 8 3/4 rears with considerably less than 550 hp in A body NHRA stockers.
