Side adjusters in a dana is just the best thing ever.
You aren't kidding the last 2 gear sets I done are the old factory deal. Not bad with a spool but that Powerlock is freakin heavy changing shims. I haven't had the opportunity to change gears on the new S60. I should trade my 68 housing in on a Strange S60 Maybe with a set of 3.23 gears. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
