Originally Posted By w2stroker
Originally Posted By sgcuda
Your staging might be erratic. After I trip the pre stage bulb, I just roll in deep enough to get the stage bulb to flicker. There is a little room for you to go deep or shallow with both bulbs on, depending on tire size and stagger. You might not be locating in the same spot every time.
this was shared with me the middle of this year. one of the things I have been working on. probably still could be better, but trying to make sure i'm in the same spot every time smile. same friend told me to make my self consistent and then change the car to fit me. for some reason I am not seeing I am all over the board with reaction times. the car is very very consistent itself.
Just so we are all on the same page what do you consider consistent.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
