Your staging might be erratic. After I trip the pre stage bulb, I just roll in deep enough to get the stage bulb to flicker. There is a little room for you to go deep or shallow with both bulbs on, depending on tire size and stagger. You might not be locating in the same spot every time.
[image][/image]
