"Its the closed minded fool to think 1960s tech can't ever be improved upon."
I don't see any fools here yet, but a couple of things, I suspect a lot of the OEM engineering today is not directed at building a stiffer chassis for 9/10ths handling as much as it is building crash test needed crush zones, and i bet the crush zones take a lot higher priority, KV was trying to sell a product, marketing was a factor in their presented result., I fail to see how bolting on a ladder frame style chassis will offer much bang for buck in more then a single axis stiffness, if nothing else, the increase in chassis stiffness/loads will be from carrying a lot less weight in your wallet.
This member is not wasting time with bolt on stuff.
https://board.moparts.org/ubbthreads/ubbt...tml#Post2532180
