For your application the 750 would work but a slightly smaller carb might work even better. The factory used 600 cfm carbs on a lot of 440 engines. A 400 hp engine only uses 560 cfm at peak power so a 600 cfm carb works just fine on a street driven 440. 90% of street driving is at part throttle anyway.
