Originally Posted By MR_P_BODY
It also makes a difference if you are using a trans brake..
if you are then use a little smaller carb and the car will
leave better off the line due to lower RPMs
wave
Not sure what you mean
When i used a brake i had 2 step set at 4300
Off foot i left at 2k, so way lower
Car 60 footed identically either way( as it should)
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight
418 BPE factory replacement headed stroker, 565 lift solid cam
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
