piston pop out? If so you can just push it back in if you don't fold the cup over. Then just re bleed the brakes
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
