Alot of thats self inflected hurt in that vid, Id never try to re crank at the line, but then again my junks never died at the line.
My thoughts are is if you cant afford a under hood and in car fire suppression system you shouldnt be spraying although not all under hood fires are easy to put out. But its better then your buddies shirts or soda.
I swear if you handed some a can of gas, labeled a can of gas and told then "Here use this" to put it out they would use it.
