The timer you show in the pic controls the key lite in the steering column.The time delay relay for the headlites mounts on top of the glovebox liner and uses a separate wiring harness,I didn't see that harness in any of the pics you posted.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
