The problem with the dial back lights is....... they can read inaccurately....... and you don’t know it.
I’ve had a couple of customers torch pistons as a result. Verified faulty light operation after the fact by comparing their dial back light vs a non-dial back light. One of them was off about 17-18deg at high rpms. Showed 38 deg at 6000rpm....... was really 55deg with a non-dial back light....... hence the burnt pistons.
I have one of the cheap red Actron non-dial back lights Jegs used to sell for $39. I had a nice old chrome Craftsman non-dial back light I bought in like 1980 that disappeared one day, and the Actron is what I got to replace it.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
