As long as there is adequate v/p clearance you can run them as tight as you want.
When you get too far up the clearance ramp of the cam, the power will start falling off.
I often ran cams on “the big side”(for the application) in my own stuff, and they usually responded favorably to looser lash settings rather than tighter.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
