Originally Posted By 5carguy
Drill out the spot welds and use a heat gun to loosen the blobs of sealer.
Thanks carguy, I have all the tools to get it apart (nice tip about the heat gun, thanks) I did re-skin the doors on my charger, so it will be the same process. What concerns me is unfolding around the rear lip. The way I see it the metal will have to unfold all the way flat or 180 degrees so the inner skin will release from the outer skin.
I was hoping to see some how to's or examples
